All manufacturers have faulty parts, it's just part of doing business. If you make a thousand pumps and one has a casting defect, and explodes in an engine later in its life, as much as it's going to really hurt that person, it's a pretty good fault percentage for the manufacturer (0.1%). There may be parts of the pump that could be strengthened, there may be ways to check the part for casting defects with the lower fault percentage, but there's always going to be the one that slips through.
As far as the rest of the pumps are concerned, 2.9 and 2.0 l engines all have had runs of faulty oil pumps. It's usually earlier models, but I can tell you that the pump for the 2 l has been superseded more than three times. Alfa engineers know about the problem, and are working to fix it. Unfortunately, there are going to be those cars that are going to have problems later in life, where the issue didn't surface before the warranty expired.
