Hi all,
I am planning to take my Giulia QV to the track a few times a year and I have read most of the post on here on this topic and I have come up with the following list of upgrades I intend to do:
Can someone please clarify for me the following:
I look forward to receiving some feedback on the above.
Thank you in advance,
Adri
- Giro Disc Front and Rear Rotors (This will be done once the stock rotors will wear out)
- Raybestos ST43/ST45 or Giro Disc GP40 Race pads
- Titanium heat shields to reduce heat transfer
- Remove the dust shields from the front rotors to help with heat dissipation
- Motul 660 or Ravenol or Castrol SRL Race fluids
- Fitting a Camber/Caster Correction Kit, that will allow some better adjustment
- Are there are any good tracking pads that can retain the wear sensors?
- What needs to be done to the wear sensors if the Track Pads do not support them, in order not to trigger any errors?
- Will the brakes temperature reading still work with these alternative Girodisc rotors and track Pads?
Adri
