What type/brand epoxy do you recommend? And are these parts removable with that epoxy (ie, lease return?)
Thanks for all of the photos.
You are most welcome! We had requests so we thought we would take a little time to share. We have more we will put up as progress continues.
Now to your epoxy question.
We typically recommend Black RTV Silicone to people when they want to buy something locally at a hardware store. It works pretty well and can be sourced pretty easily,
If you are planning to install some items to a car that you would possibly return once the lease is up we would recommend using a clear silicone. It is something you can purchase at a local hardware store as well. The cure time is longer, but it is pretty easy to peel off once you are done. Just take some time and mask the area around so it does not ooze out and get on the nice soft materials all around. We would also recommend getting some Blue Painters Tape and masking the item down for overnight so it can cure. Once done, simply peel off the tape and you should be all good.
At our shop we typically use a two part professional epoxy or Window Weld Silicone if we want it on permanently without a chance of coming off.
Some pieces can also be installed with 3M double side tape.
Hope that helps and as always do not hesitate to reach out.
