Good luck! Hope the dealer knows about the warped rotors issue.. thinking it might be that which would mean a replacement may well solve! That's a long time on the updates.. mine said it'd be around 45 minutes (and mines had none!)... let's see
Hi tadslc,I was going to wait until finished with the service but this may take a while.
Took my car to the dealership Wednesday for the following items:
My car has approx. 2,900 miles on it.
Oil Change
Software updates
Dash rattle
Brake noise (CCB)
Possible infotainment update
Turn down sensitivity of the alarm
Took 2 days to just load the updates, I'll let y'all know which ones when the car returns. Did the oil change, they say they fixed the dash rattle, no infotainment update available for me :|
Re the brakes, they hear the noise I'm talking about but are unable to figure out what / why. Dealership has gotten STAR involved, may have to replace pads + rotors but are waiting on STAR to guide them. STAR wants sound bytes sent but they're have a problem sending them a clear enough one to make a determination. I have a feeling I won't get my car back until STAR is finished.
They also found out I had a bent rim, inside rt. front, and will be fixing that.
So far I've been happy with my dealership service department. Will provide an update when I know more.
Thanks Andrea,Hi tadslc,
Sorry to hear about your concerns with your Giulia! Please don't hesitate to PM our page with your VIN for further assistance if needed.
Andrea
Preventive maintenance only, nothing more. Plus I wanted to get the other issues addressed or at least noted.I thought the car was supposed to go longer between oil changes.
Don't see this as a warped rotor issue, doesn't feel like that at all and being that they're carbon ceramic, I don't think there a lot of service info on these. My dealer thinks they'll replace the rotors and pads though but they're just waiting on STAR.Good luck! Hope the dealer knows about the warped rotors issue.. thinking it might be that which would mean a replacement may well solve! That's a long time on the updates.. mine said it'd be around 45 minutes (and mines had none!)... let's see![]()
Tecnico or 5 hole rims? Damaged by road hazard or as-made?They also found out I had a bent rim, inside rt. front, and will be fixing that.
Hi tadsic,
I am glad you are happy with the local dealer. I believe I use the same dealership in Birmingham. I have been there twice for oil changes and am really pleased with the service
My Q4 has 15,000 miles and has been flawless.
Yesterday for the first time I spotted another Giulia in town. Beautiful, Blue. Spoke with the driver for a few minutes. He was happy with his car and had had no issues.
Some time ago on this forum I started a post pertaining to the noise on my brakes. It's hard to explain, my command of the English language being as it is.Good info tadslc!
I don't think it's really possible to warp CC rotors! Hopefully it's just some material build up and new pads will help. Is it squealing, thumping or knocking? Drilled rotors will flutter regardless. But it's slight and not offensive. It's the holes and slots passing the edges of the pads. Check to see any shims or paste are properly in place.
I'm due for new pads on my 360 and will replace them with Posiquiet ceramics. The metallic Brembos are higher performance but sound like crap and squeal at low speed.
Maybe you got some debris in the pads or rotors early on? Enough to compromise the surfaces without making the telltale sounds of vibration squeal or low thickness squealers. And with the way ceramic rotors are made there's no telling what may have happened. There is already a thread on bad steel rotors on Ti's. It's a tough problem to find because it's in the metallurgy of the casting and not visible to the naked eye. Probably some screw up in the cooling process where the cauldron clogged on a set of pours and they cooled unevenly, resulting in different crystal structures and friction properties. A whole other bunch of issues could be involved with carbon. Glad they didn't explode on you.Some time ago on this forum I started a post pertaining to the noise on my brakes. It's hard to explain, my command of the English language being as it is.
It's nothing like you describe, its more a loud rubbing sound when applying your brakes and I don't think it was there early on in my ownership but hasn't really gotten any worse over time after it started.
Hi tadslc,Some time ago on this forum I started a post pertaining to the noise on my brakes. It's hard to explain, my command of the English language being as it is.
Yes they have Kori, STAR is sending them a set of brake pads for the dealer to install. We'll see...Hi tadslc,
Has your Studio addressed the brake noise for you?
Kori
Please keep me updated!Yes they have Kori, STAR is sending them a set of brake pads for the dealer to install. We'll see...
